Winter time battery storage
Do not leave your batteries in the refrigerator. This is not good for these types of batteries. Go on you tube and check out many of the top dogs suggestions. They will all back up the statement of refrigeration storage being a bad way to store them. Check out Drone Valley. On you Tube. This guy will certainly get you headed in the right direction instead of following hear say.
The only negative that might provide some argument against storing in the fridge is that if condensation forming on the electronics. The low temperature will have no negative effect on the cell chemistry. It is well known that chemical reactions that result in LiION chemistry degradation proceed at an higher rate as temperature increases. Condensation isn’t a problem if the batteries are in a sealed bag and allowed to return to room temperature before removing.
KiKiHUN
