Battery Care - All drones
Can you explain that a bit further? How do you do that?
Sure, If you’ve purchased a combo pack the hub can be used as a power source for other devices such as your cell phone iPad ect. Plug the cable with the usb side into the hub and press the button on the side and plug to other end to the phone ect. it will draw power from you drone battery as a charger and will deplete the drone battery as it charges.
Reactions: Cafguy
Thats how I discharge..With the Air2s, DJI included a little adapter that fits on the battery and lets you plug a usb device into it. I charge my phone and anything else with them to get back down to 60.
This is the one for the Air 2s that will also discharge the batteries down to 60%:
https://www.amazon.com/dp/B08J7M1MPL?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_3
These ones are popular because they charge all the batteries at once. This is a trusted brand, affectionally known as the "YMCA" charger, due to the logo. These ones do not discharge the batteries down to 60%, but there is a switch you can toggle to charge them up to 60% or 100%. The one for the Mini also shows the charge cycle count for each battery.
Mavic 3:
Amazon.com: Hanatora LCD Parallel Charger with Storage Charge for DJI Mavic 3/Cine/Classic/Pro/Enterprise Battery,Display Rapid Multi Charging Hub Drone Accessories : Toys & Games
www.amazon.com
Mini 3/4/5 Pro:
https://www.amazon.com/dp/B0BG81DM8F?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_8
I have one of these for my Mavic 2 Pro's..... works GREAT
Reactions: Rchawks
doaner
