Would like to find replacement mavic pro
My drone has error of forward motion I have recalibrated but doesn’t fix I am looking for a replaces drone for my control anyone have one laying around that you don’t want anymore as the program to fix is saying drone is out of options they have discontinued the mavic pro
We have a Sub-Forum "Classified" you might want to check there…
there are also local and internet sources ( I don't know about these, nor do I endorse them…) Facebook Marketplace, Craigslist's, eBay, your local hobby stores, Drone repair centers, Pawn Shops, etc…
Or you can try having it repaired. There are numerous repair centers that will give you an estimate and return it if you do not want to spend that much. Worse case, you would only be out the cost of postage…
Or, you could just give up the Ghost and buy one of the many fine used drone fro sale… Just make sure it is unbound from the sellers account.
Good Luck!
Hello from the Crossroads of America oldmilkman1@.
I haven't used the services, but they are an approved vendor here on the site.
They may be able to repair your drone.
Here are a few more that may provide repairs.
Good luck and welcome to the Forum. :cool:
Forward vision sensor error?
Not sure what a forward motion error would be.
I’ve seen the forward vision sensor fail because a ribbon cable fails.
Probably something I could fix.
THIS!
If you crashed it or Dropped it at one time, The Mavic 1 is notorious for solder chipping from the sensor/camera board above the gimbal, The Ribbon cable, over time will get more and more Brittle and won't take to many hard landings before its toast!
You probably should just replace the board and ribbon cable.....Good as new.
Reactions: LoudThunder
yes i have one ready and another 2 just about ready and can probably get the one you have back on track
Greetings from Chicago the Windy City, welcome to the forums.
FLY SAFE & FLY SMART
I have a Mavic Pro drone, which I will be selling. But I am selling everything., not just the drone.
Reactions: MA2 317
TATER2937
