Y'all figured out how to load fly onto android 13 yet?
High_Order1
near Oak Ridge, TN
Won't be able to check in much, but
I don't want to reinvent the wheel either.
Here are the steps I've already taken:
I can connect it to wifi, and navigate to the DJI FLY download page.
The tablet (I assume) will not allow me to click on 'download'
Your site will not allow me to use my computer to download the apk from the same page.
I did find a copy of the apk online, I used a cable and moved it from my laptop to the tablet.
The tablet will let me select the apk in downloads, but the menu in files only has 'open with'. Double clicking or long pressing does nothing.
I have enabled developer options. There is nothing in there that suggests it can allow unverified apps to be loaded.
There is no Settings > Apps > Special access > Install unknown apps setting.
There is a setting that says the bootloader is unlocked, but I don't know if that's helpful in this situation.
You need to enable Developer mode on your phone to sideload any apk's
Hello Rexter.
Did you see above where I stated I had enabled developer mode?
Also, may be nothing, but I noted you called it a phone. It is a tablet, for sure, but android thinks it's a phone...
UAScend
