Found a Mavic 2. In the Snoqualmie Washington area.
Check the SD card.
Sometimes the owner may put information on the card as a word document.
I do.
If it has FAA numbers, that may help.
DJI might help with the serial number?
Good luck. 👍
I put contact info in battery compartment.. Good luck and thanks for making this effort!
I use the SD card to place contact info as in Post #2
I have used the free stickers from Pilot Institute, But that was on my first drones one was a defective HS720 that was sent back, second HS720 was barely better, It go sticker, Then got a Ruko F11 GIM it got a sticker, after that moved on to DJI Mini 2, added a Mavic Air, and a Mavic Air 2, and Now just got a Mavic Air 2S. So I have a label maker that I use for Reg# and I also put my cell number on each Drone. Next Month I will have to get New Reg #s for my DJI drones as by then I should have my part 107, and each DJI will get its own FAA Reg #
Also, the pictures and their EXIF data may tell a story location about the owners home address or area if any pictures were taken at a residence. May be able to track them down that way.
NIKLM
