“Aircraft disconnected” flight data help
I assume this will be getting sent in for service.
Before sending it in, try some tests with a normal RC (GL6D10A) which is NOT running the latest firmware (the one with Multilink)
Reactions: BudWalker
I wished I had access to one of these older controllers.
Is there a method to roll back firmware for the cendance remote controllers?
also of note, is that I have used two different cendence remote controllers and still this issue persists.
I suspect it's not a HW issue in the controller. Rather a FW issue. Are they both running the same FW?
Yes, I suspect they are both running latest firmware.
In GO4 app, press and hold the 3 bars on the top right corner until the firmware management screen appears.
Select the firmware version you want to downgrade.
Reactions: Lapeer20m
I ended up sending the aircraft back to dji in California. Received an update today. No charge, replaced under warranty:
Main Controller Module
Quantity: 1
Net Price : 1,376.00
Whitehammer661
