Hi Folks been a long time member and purchased a
mini 3 pro gave my other drones to the kids and back flying again.
Mini 3 pro got me hooked again. From North Queensland Australia
Hey John,
As a New
Mini 3 Owner, Welcome from the Hampton Roads area of Virginia, USA. In case you did not know, we have a Member's Map in the Upper Right of the Title Bar.
mavicpilots.com
Since you live in Australia, and your New Baby is a serious Drone, and you may not have known. there are specific laws and rules for you to follow, please check to ensure these are current.
According to CASA, drones are allowed in Australia for recreational and commercial use, subject to CASA regulations. Read on for details.
drone-laws.com
We'll look forward to all those beautiful Photos and Videos from your neck of the Outback.
Because you have a new baby, I'll offer some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the
Mini 3 Pro, including the User Manual.
At DJI Download Center, Learn aboutDJI
Mini 3 Pro
www.dji.com
Happy, Safe and Legal Droning…
