Battery Explosion
I've got a bunch of RC batteries (some large capacity, some small capacity) in a drawer in one of my rooms, they are all unprotected. I guess I need to either put them outside in a safe area or get them to a recycling center ASAP.
This is your friend:
Reactions: StevenBrodsky
Is that 280? 304 each? 329? I really need to have that sign !!!!!!!
47.4KWh. Not bad. I am surprise you haven't compressed the packs. You should.
I’ve had good results using the filament tape. Each battery has a 100 amp BMS so I’m limited to around .4C charge/discharge rate which really doesn’t stress the cells.
Staying on topic, I worry more about the drone batteries getting unruly than these.
Reactions: zeusfl
That is what I read that they puff only when draining high amount of amps but with all the juice you have they are sleeping. LOL nice setup.
Reactions: Radioman
Thanks I just ordered for $9.99 THANKS AGAIN !!! LOLLL
Reactions: Radioman
Reactions: Radioman
Oh wow those battery packs look insane!
What do you use them for?
The small one is a portable packs inside a case to charge drone batteries at the field. The LiFePo4 packs (the blue one) is battery backups for my house. I can power the refrigerator, lights, TV. Technically have sufficient output for A/C and Stove but is not the intention since will last only 1-2 hours if I do that. but the rest will last about 24-48 hours on batteries.
What do you see there is only half pack. Are 16 of them. 8S2P configuration for 24V.
Reactions: Yaros
I have videos. Let me show you.
This was years ago. In that flight it peak 274 Amps. Id had a Kontronik Cool Kosmik 200A HV ESC.
Whoa! That’s was pretty whack…
JeffN
