Bay Area/San Jose check in
ruhrho
San Jose, California
Hey y’all, just another new Mavic pilot check in. I just picked up a Air 2s after doing a bunch of research on a new camera drone. I ended up gleaning a TON of info from this forum that lead to my purchase, so I thought I’d join up.
I’m not a stranger to flying stuff (mostly sailplanes), but I’m new to the DJI world so I’m sure there will be some adjustments, lol. With any luck, this weekend I’ll run through a few batteries and start getting some stick time on this airframe, and getting hours in.
I also have a bunch of reading up on the manual for it and one of the things I’ve read up on here is some of the automatic features in the software aren’t totally intuitive to get to. Namely these are updating the home position, auto land, and manual override with RTH.
I’m sure there will be other things that’ll come up in time, but for now it looks like it’ll be a fun aircraft and I’m super excited about the camera on it.
- Juliette
Welcome from the Hampton Roads area of Virginia, USA. I am a Mini 2 Flyer and I too know the excitement of flight.
First off, being in a sail place is entirely different from first-person view (FPV) looking at the screen through the camera of your drone. The distances and perspective from the view will fool you every time and you will wind up in a tree… In the sail plane you are "First Person" and your view is true.
So, if I may offer some advice. Do not let the excitement of the moment get the best of you. When you are going out to fly, do it slowly and deliberately. Get used to a set procedure and even practice it.
Happy Droning
Welcome to the forum! :)
Thanks for the welcome everyone, I did the initial power-on last night and basic systems check out (minus IMU and compass checkout) to make sure everything was sort of working. If the rain abates in the Bay Area today, I’ll get it out for its first flight.
I’m pretty excited about getting this in the air TBH. I have a much cheaper camera drone and let’s just say, the camera was disappointing the first time I took it out, which lead me here…
Up next I’ll be working my part 107 and getting a robust travel kit together.
Welcome to Mavic Pilots .
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to Mavic Pilots! :) Enjoy the forum! Thumbswayup
Welcome to the forum from the beautiful woods of Maine!
I think LoudThunder covered most of it and as dirkclod said, search the forum (use key words) and if you don’t find an answer, post your question and I’m sure you’ll get a quick response. Patience and Practice are your main friends, using a wide open field (football,baseball or farm) will get you the confidence to fly in crowed areas.
Fly safe and stay safe!
- Juliette
Welcome to the forum from the mountains of Colorado! I love the Bay area! Very beautiful area I think. Happy and safe flying!
Greetings from Birmingham Alabama, welcome to the forum!​
Welcome aboard pilot!! That is one target-rich environment you have up there!! Show the family just how beautiful the San Jose area is . . . enjoy yourself!!
Hey Juliette,
Another new drone owner from San Jose here. Good luck!
p.s. Have you done any research on where to fly in the South Bay? Just from my mild research I'm getting pretty discouraged...
Reactions: Skywatcher2001
Hey Juliette,
There aren't a lot of great areas due to how congested the airspace is with SJC, Moffett field, Palo Alto airport, Reed-Hillview, San Martin airport. Ironically the fields that we fly RC sailplanes at are poor choices as well due to the proximity of heliports, etc.
When I've flown drones/quads in SJ, I usually head out to the hills to the south/east/west.
dominicus15
