Beginner needs in person training in CT
Lucky I noticed your posting under the New Category… You should also poast in the Pilot Check In Sub Forum so we anc formally welcome you…
But be that as it is, WELCOME!!!
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Connecticut , there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Air 2, including the User Manual.
Fly On and Fly Safe…
Welcome from Texas.
Don’t be scared of the drone; even though I was at first. Get well about the trees and any buildings and just fly. You will learn quickly that it is not scary. Everyone goes through it as we can ruin an expensive tool/toy in a flash. Also, lots of good info on YouTube from drills to learning more about your drone.
Getting to know the app side with the settings will get your confidence up quickly.
Reactions: LoudThunder
Welcome! Use care and start slow. Take the drone up and fly around slowly not even using your camera just learn how it "feels". Pick out 4 points in front of you and simply fly to those points mixing it up a bit, once you are bored with this, Fly your drone around and test the brakes -get an idea of how long it takes for your drone to completely stop at various speeds. Finally using only the map view- move around your points again making sure to divide your attention about 80% Drone and 20% screen -Its important to Know exactly what the map view is telling you! Now you are ready to use the camera view again Remember you must always see the drone!! Do not get in the habit of only using your screen for flying! Doing so will not only cause you to eventually crash but is also not legal.
Welcome to the forum from the beautiful woods of Maine!
There are a lot of good videos by Flytpath on YouTube that start with unboxing and go up to your first flight. I used him when I bought my Mini and was very pleased with his instructions. Fly safe and stay safe!
Practice doesn’t make perfect but enough of it will make you proficient. I learned to fly on a Symantec X8SW which was little more than a toy. After a couple of flyaways that resulted in long walks in Texas summer heat, I learned to keep it close and fine tune my control. I took the drone fore “walks” and just played with it, enjoying pics and videos shot.
When I upgraded to the MA2 it was almost boring because the thing almost flys itself (fortunately I outgrew that). But the best thing that I loved right away was that when you let goof the sticks, it stays right where you left it. Hovering is stable even in a brisk wind.
Keep it close and play. There are YouTube videos on exercises you can do to hone your control. Here’s one, for example:
Drone Exercises
Good luck!
cjd54
