Best memory card specs for RC Pro and what can be done with it?
lomposlapos
What are the best memory card specs to use in the RC Pro?
What can you do with the external memory? For example, store duplicates of the images, maps.... what else?
Can I simultaneously save to the memory card the same exact quality video and still files that are being saved to the drone's (Mavic 3) memory card while in-flight? That is creating two identical copies of each video, image? If yes, does this hinder the controller's other function?
1. Same specs as the ones for the drone, except as much memory as possible.
2. Anything on the RC Pro can be copied to the external memory, and anything on the external memory can be played back on the RC Pro or copied to it. You can remove the card from the drone and play it back on the RC Pro and any connected monitor through the mini HDMI port or compatible external USB-C port monitors.
3. External memory cannot simultaneously record in the same original quality as the drone card, because this would use up too much of the bandwidth needed for control. It believe it can, however, be used to simultaneously record the low res video cache, if you specify that location, instead of the RC Pro internal memory.
Reactions: Drone Master
themirac
