Bonjour from Swadlincote UK
Grabbed my little Mavic Mini. Just upgraded to the air2s and can’t wait to get playing locally.
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Since you are back in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
I know you are an experienced Droner, but with a New Baby, here is some Good Old Fashion Advice…
Below are the links to all of the downloads offered by DJI for the Mini and the Air 2S, including the User Manuals.
Happy, Safe and Legal Droning…
Hello from the Crossroads of America Dinksi.
Nice to meet you Darren. 🤝
Welcome to the Forum. :cool:
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum. Traveling with a drone is fun and congrats on getting an air 2s, which you'll find more functional than mini. If you need a handy case to protect your drone, you can check our well-rated case for air 2s Lykus MA230 Hard Case.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to the forum! :)
Hi I’m Darren from the UK,
Only just back from a secondment in France and Turkey. Grabbed my little Mavic Mini from Fnac and loved the French countryside from aloft. Just upgraded to the air2s and can’t wait to get playing locally. Thank you for this forum and letting me in…😌
Welcome, from across the water in Dublin
vanillasky
