Bonjour!
surfin_bird
Canada
Quebec pilot signing in here, always been an aviation fanatic and this new drone tech gives me the chance to be the pilot i never had the money to become. So far i got a Mini 2 SE and am studying for my drone licenses so i can fly the bigger boys. The DIY stuff is also incredibly interesting, i'm a bit of a hardware hacker and software developer so i'm definitely interested in mods. Kinda mad that DJI stuff is so locked down, me being the type to run linux on my computers and root and flash custom ROMs on all my android devices; but the aircraft themselves are amazing pieces of technology. Glad to be here.
Welcome to the forum! :)
Welcome from Halifax, NS
Welcome to the forum. We look forward to your participation and your view of the world.
Yesss ! Un francophone ! Bienvenue, ami québecquois.
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 2 SE, including the User Manual.
Fly On and Fly Safe…
Vlad_Zherikhov
