bummed new Air 2 owner LOL
Talent, Oregon
Hey friends,
I'm Andrew and brand new to the drone world.
I purchased a used Air 2 recently to help get some Real Estate shots of our home we are selling here in Talent, OR. After a few flights, I was at my mom's and trying to get an overhead shot (she is selling her house too) and all of a sudden, it just started flying backward at top speed! It was literally about 15 feet above my head. Thankfully it hit a tree a few blocks over and because of the video, I was able to track it down. Since she lives in a busy neighborhood, I thought maybe it could have been interference of some sort. I updated everything, calibrated everything and tried it out again at home... It seemed to work and I was able to fly through one entire battery pack. I put another pack on and after initial take off and hovering above me for a few moments, it did the same dang thing... just took off at top speed backwards! I hit RTH and it stopped moving but would not actually initiate the return to the starting point. The RTH canceled and once again it took off backwards. I tried RTH multiple times with the same response. I finally figured out that I could turn the drone and increase/decrease altitude so I started flying it backwards and was able to gently crash land in my backyard.
Of course the dude who sold it to me will not respond to any of my messages now so I have a drone that I'm afraid to use.
I'm going to put this into the forum to see if I can get a little help and hopefully have a drone I can use safely again.
Cheers to you all!
Welcome to the forum! :)
I'm Andrew and brand new to the drone world. I purchased a used Air 2 recently to help get some Real Estate shots of our home we are selling
First off, I cannot help you with what might be the issue with your drone but you need to know that you are probably "flying on very thin ice" legally speaking. But you cannot be doing what you are doing for your Mom… If you are going to take real estate photos, even for your mother, you need a Part 107 License from the FAA…
But, as a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs more than 250-grams (0.55 pounds) and while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live Oregon, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Air 2, including the User Manual.
Fly On and Fly Safe…
Welcome to our forum, from Hauptmann, in Hurst, Texas!
You'll love the flexibility of vantage points an aerial camera platform affords--you'll get shots and videos you could only dream of before! I fly a Mavic 2 Pro now, but will soon add a Mini 3 Pro to my “fleet”.
I have not experienced the behavior you describe. Wish I could help you. We have over 150,000 members—many from your part of the South--who enjoy helping each other get the most out of our hobby. Most of the questions you'll have will’ve already been addressed, and are easy to search. If you have NEW questions, just ask!
I attached a couple of links below, which will make learning piloting and photo/video skills easy. They specifically refer to the Mini 3 Pro, but his “moves” apply to any drone (DJI, anyway).
Glad to have you with us!
Rich R (aka Hauptmann)
... I put another pack on and after initial take off and hovering above me for a few moments, it did the same dang thing... just took off at top speed backwards! I hit RTH and it stopped moving but would not actually initiate the return to the starting point. The RTH canceled and once again it took off backwards.
That's an interesting incident and definitely not something you should experience in normal flight.
The recorded flight data might be helpful in finding what caused it.
Go to DJI Flight Log Viewer | Phantom Help
Follow the instructions there to upload your flight record from your phone or tablet.
That will give you a detailed report of the flight.
Come back and post a link to the report it gives you.
Or .. just post the txt file here.
Someone might be able to analyse it and give you an understanding of the cause of the incident and how to prevent it in future.
Did you launch from the same spot for all the problem flights?
Hello from the Crossroads of America thereverend801.
Nice to meet you Andrew. 🤝
As stated above, retrieve the flight log(s) from the device and post a link.
There are members here that can read the logs and see what happened.
Good luck and welcome to the Forum. :cool:
Welcome to the forum. We look forward to your participation and your view of the world. Sorry about your situation. Looks like you are getting some solid advice, already. Also post your question in the MA2 forum. There should be plenty of help.
I added a post under the crash and fly away help forum with the flight data :)
The thread in question was hung in the Approval Queue. I just approved it so move all discussion about the incident to that thread.
Air 2 flying backward on it's own!
Thanks
JReynolds078
