The
Mavic 2 Pro/Zoom has three flight modes, plus a fourth flight mode that the aircraft switches to in
certain circumstances: Make sure you are in P Mode.
P-mode (Positioning): P-mode works best when the GPS signal is strong. The aircraft utilizes GPS and
the Vision Systems to locate itself, stabilize, and navigate between obstacles. Intelligent Flight Modes
are enabled in this mode.
When the Forward and Backward Vision Systems are enabled and lighting conditions are sufficient, the
maximum flight altitude angle is 25°, the maximum forward flight speed is 31 mph (50 kph), and the
maximum backward flight speed is 27 mph (43 kph).
Note: P-mode requires larger stick movements to achieve high speeds.
The aircraft automatically changes to Attitude (ATTI) mode when the Vision Systems are unavailable or
disabled and when the GPS signal is weak or the compass experiences interference. When the Vision
Systems are unavailable, the aircraft cannot position itself or brake automatically, which increases
the risk of potential flight hazards. In ATTI mode, the aircraft may be more easily affected by its
surroundings. Environmental factors such as wind can result in horizontal shifting, which may present
hazards, especially when flying in confined spaces.
S-mode (Sport): In S-mode, the Vision Systems are disabled and the aircraft only uses GPS for
positioning. The maximum flight speed is 44.7 mph (72kph). Intelligent Flight Modes are not available
and the aircraft cannot sense or avoid obstacles.
Note: In S-mode, aircraft responses are optimized for agility and speed making it more responsive to
stick movements.
T-mode (Tripod): T-mode is based on P-mode and the flight speed is limited, which makes the aircraft
more stable during shooting. The maximum flight speed, maximum ascend speed and maximum
descend speed are 1 m/s. Intelligent Flight Modes are not available in T-mode.
Good luck!
