Can't upgrade off of 01.300.0400 - Mavic Pro
ether_rich
Tacoma, WA
Tried many options to install any new firmware from 01.300.0400 but nothing works... Used Assistant 2 from mac(reinstalled multiple times), tried from Go4(reinstalled multiple times) via remote and directly via wifi and even DroneZbreak. Read many threads on different methods all which have failed. Any help would be appreciated.
Assistant 2 is kinda worthless in this situation. You’ll need to use Dumldore on a windows computer is the most reliable way to do it. jezzab/DUMLdore
Download the firmware you want to use from the instructions inside Dumldore which will direct you to download the dankdownloader tool.
If flashing to one of the 01.04.xxxx firmwares you’ll need to do the update at least twice. It’s a big update so it takes two tries to get it all the way updated. Try to use the same battery both times.
I know it’s crazy the manufacturer doesn’t make a tool that’s capable of updating to the latest version. You would have had to update incrementally driving yourself crazy in the process
deepdark
