Charging Mavic Pro batteries in UK
Taffybrian
Travelling to UK Dec, Apart from using a car charger - the one I had packed up after about 3 charges. any suggestions on how to recharge batteries. UK power is 240volts
the charger that came with the mavic can use 100 to 240 volts so all you need is an adapter for your US socket to a UK one and then you can charge them up as normal
Good to know, I now seem to recall that on the charger data label.
I’ve used various camera 240v chargers on 110v mains with pin adapters overseas, but thought the other way around was more potential for problems of higher voltage.
whathesaid
