I live at Lawrenceville,across the river from Vincennes,Indiana.Great to know that works.. Where are you located? ? Looks like Southern Illinois where I'm at
They will,but with the battery's inside the warm vehicle,they work a lot better in cold temps. I also let the Mavic pro hover for around a minute to warm up,before flying. It's not a problem as I also use this time to check the camera settings,and make adjustments,before the flight.I thought that freezing temperatures will give problems with the Mavic battery. In general batteries dont like low temperatures. Take care!!!
That was the point of my post... it does not matter how cold it is outside when flying... it only matters how cold the batteries are. The firmware in the batteries will limit thrust on certain temps and then not allow the motors to be activated on other temps
Flying 20 minutes in freezing temps will bring down the temp of the battery to zero and it will certanly has impact on the capacity of the battery
Flying will actually _increase_ the temp of the battery. As current is drawn and the chemical reaction takes place, the temp of the battery increases.
Next time you fly, feel you battery right after it's use. This was easier to feel on the Phantom batteries as they were more exposed.
To a certain extent, the warmth eminating from the CPU in the drone itself will keep the battery warm. If it gets really cold, you can tape an iron oxide boot warmer to the outside top.Ok, think you have a point, will check it
Will the iron-oxide affect the GPS sensors and or compass?To a certain extent, the warmth eminating from the CPU in the drone itself will keep the battery warm. If it gets really cold, you can tape an iron oxide boot warmer to the outside top.
The controller is a different matter -- cold weather will effect the RC and phone/tablet quickly and servery shorten flying time. Short of piloting from a car, I have no solution that I've tried, though the iron oxide packs might help there too.
Yes,that is correct! As the batterys discharge they build up heat,now how much heat they produce at freezing temps,is kinda a "grey area",but starting out with warm batterys helps a lot. I haven't flown my Mavic Pro in 32 degree or lower temps........yet! But I will before the winter is over!Flying will actually _increase_ the temp of the battery. As current is drawn and the chemical reaction takes place, the temp of the battery increases.
I'm not sure. It never did on my inspire, but the battery was some distance from the CPU in that case. I'll let you know when it gets cold around here.Will the iron-oxide affect the GPS sensors and or compass?
Yes,that is correct! As the batterys discharge they build up heat,now how much heat they produce at freezing temps,is kinda a "grey area",but startying out with warm batterys helps a lot. I haven't flown my Mavic Pro in 32 degree or lower temps........yet! But I will before the winter is over!
Since this is a thread about cold weather flying, what does this have to do with the subject?
- Check the status of the battery in the DJI GO app after powering on the aircraft. Keep an eye out for app alerts during flight. If the DJI GO app displays a warning that battery cells are abnormal or damaged, stop using the battery.
- Follow the stated temperature for battery use.
- Don’t charge the battery right after a flight because the battery’s temperature may be too high. Avoid charging the battery outside of the stated charging temperature range.
