Aetha's solution will not work in FLIR Studio?I can't use the TIFF in FLIR studio, unfortunately. I don't understand whey DJI has a proprietary file type when their thermographic software is so poorly designed. I think I will have to go with a different drone. Big bummer
Does anybody know how I would convert the jpeg images from the thermal camera on the mavic 2 enterprises advanced so it can be used in the Flir thermal studio software? The DJI thermal software is so bad and the flir studio software is great but it won't read the jpegs from my camera.
I would double check with Atygeo on FLIR Thermal Tools though. Some of these converters are only making a RJPEG into an RTIFF and not making them compatible with FLIR software.Hurry and buy as they seem to raise their prices every so often.
590 Euros ($645 as of this date)
ATygeo Thermal | Conversion to TIFF from DJI M2EA | ATyges ®
ATygeo Thermal. ⭐ ATyges, Drone Specialists . ✅【DJI Oficial Reseller】✅.atyges.es
$199 Monthly, $299 Annually
Drone Thermal Tool
dronethermaltool.com
$995
ThermoConverter | Converting radiometric data made easy
Easily convert radiometric data from DJI & Autel for use within FLIR Thermal Studio & FLIR Tools. Easy to integrate into your existing thermographic workflow!thermoconverter.com
Hey,Hi Guys, I want to share my findings, here I made a simple tool with gui that let you convert any type of DJI thermal image into a Tiff image with one band containing temperature in celsius.
I made it using the DJI thermal SDK and python.
It is Hosted on my website and packaged as a self extracting .exe with 7zip,
I needed to package it because it needs part of the Dji sdk as dependency.
just download it, run(extract) where you want, and after extraction open the GUI that is the file called: "DJI Image Processor.exe"
this is the GUI.
It works with all dji models supported by the DJI Thermal SDK
This is the link: https://miro-rava.com/documents/DJI_Image_Processor.exe
Note: The section called"DJI Air 2 -Frame Extractor" was used for another purpose: (extracting geotagged frames from Air 2 videos giving as input a starting altitude)
Cannot open the file as [7z] archive
Unexpected end of data
Hi, this is the first time i get this complaint, it means that the download wasn't complete probably,Hey,
I get an error trying to install it:
Cannot open the file as [7z] archive Unexpected end of data
Good To know that now it works.Thanks for your very fast replay. Last week I tried downloading it several times on different occaisons and it always was very slow, around 50kb/s. I suspect that this had something to do with the error I got.
I downloaded it again today and now everything works as expected. I did not have to change anything.
Thanks a lot for creating this, I will test it out some more in the next days.
Best regards
Hannes
this is really cool, thank you.! and the fact you include the src code is so helpful - have you considered hosting this on github and turning it into an open source project?Good To know that now it works.
If you are interested (I don't know if you use agisoft metashape) in converting the images into an orthomosaic or a 3D model with temperature data, at this link you will find the complete procedure i posted this morning.
this is my workflow in metashape: DJI Thermal Images Processing (converter to .tiff) SOLVED!
for any other questions don't hesitate to contact me!
Hi, thanks for the compliments,this is really cool, thank you.! and the fact you include the src code is so helpful - have you considered hosting this on github and turning it into an open source project?
you said it, I've done it!this is really cool, thank you.! and the fact you include the src code is so helpful - have you considered hosting this on github and turning it into an open source project?
thanks! Ill have to polish up on my python, but ill be sure to add some things to ityou said it, I've done it!
I've just created a github repository at this link: GitHub - MiroRavaProj/DJI-Tools-and-Stuff: This is a project that tries to combine various DJI related tools
I hope that this is useful for everyone!
