DatCon can accept Mavic .DAT files
VelH is the .csv column that shows horizontal speed. The documentation is a bit arcane. I'll change that.
I was able to retrieve the .txt file from my iPad DJI Go App 4.0. Didn't have any problem converting it to a .csv. The .dat on the tablet isn't the same as the .DAT on the AC and can not be processed using CsvView/DatCon.
Ok so I see what my issue was. The mph displayed on screen of the dji GO4 App displays mph as fps (feet per second). So my 64.5mph was actually, 40mph. The GO4 App has had several updates with plenty of opportunity to correct a misleading issue. I bet if the display stated the a/c was traveling slower then it actually was, they would've corrected it a long time ago. No they would rather allow everyone that doesn't know better to post in social media about how fast they're able to fly.
It's no wonder why the Flight Autonomy does not function properly at times.
Excellent software. I am learning a lot using it.
Thanks BudWalker for making it.
Rob
i only can acess 3 last fligth on dat log is normal?
Sorry, I don't quite understand your question. Are you referring the number of .DAT files on the Mavic? Or, are you referring to number of flights inside a .DAT that is generated by DJI Assistant 2? In both cases I'd have to say there is no "normal".
Just a suggestion. I use Google Translate when I'm posting with my German colleagues. If it weren't for that they wouldn't understand what I'm talking about. Just a suggestion.
Hi sorry i try again
i have a mavic and try get the data on internal disk i have this files
FLY061.DAT 450 MB (471 867 392 bytes)
FLY059.DAT 450 MB (471 863 296 bytes)
FLY064.DAT 410 MB (430 211 072 bytes)
FLY066.DAT 389 MB (408 649 728 bytes)
FLY065.DAT 268 MB (281 018 368 bytes)
FLY063.DAT 173 MB (182 288 384 bytes)
FLY060.DAT 100 MB (105 676 800 bytes)
FLY067.DAT 78,6 MB (82 481 152 bytes)
FLY062.DAT 64,0 MB (67 141 632 bytes)
FLY056.DAT 63,3 MB (66 453 504 bytes)
FLY058.DAT 51,8 MB (54 403 072 bytes)
FLY057.DAT 10,4 MB (10 977 280 bytes)
FLY068.DAT 6,75 MB (7 077 888 bytes)
FLY069.DAT 4,64 MB (4 870 144 bytes)
FLY070.DAT 376 KB (385 024 bytes)
And i get to my pc then i try the program datcon all this files and only get 4 flight records and this 4 fligth are the last 4 i fly
FLY059.csv 37,6 MB (39 434 470 bytes)
FLY061.csv 34,4 MB (36 150 623 bytes)
FLY064.csv 30,2 MB (31 700 102 bytes)
FLY065.csv 18,9 MB (19 910 558 bytes)
Now my question is i have about 25 fly where i can get rest the records?
So, you have retrieved FLY063.DAT from you Mavic and it resides on your PC? What happens when you submit FLY063.DAT to DatCon? What version of DatCon are you running?
Im using 2.4.3
She show me only Recording start, dont show the flight start
Im using 2.4.3
Is a FLY063.csv is produced when the Go! button is pressed? The reason that Flight Start isn't shown is that there isn't a flight in the .DAT. Also, there is no motorStart.
Yes i know i have press GO! but dont have flight record i dont want him. The problem its in this all files only have the last 4 flys?
Only this files shows Flight Start
FLY059 FLY061 FLY064 FLY065
Please provide a Dropbox link to one of those .DATs that don't have a flight. I'll take a look. Since there are so many files like this there may be a bug in DatCon.
Do you know that a .DAT is produced every time the battery is turned on? Even if there is no flight?
Dropbox - flylogs
Say if works
Done all upload
As I mentioned, a .DAT is created every time the battery is turned on; even if there is no flight. FLY063.DAT is an example of this. batteryOn occurred at 2017-2-5 20:3:10. local. There was no motorStart and no acquisition of satellites. I suspect you had it on your desk checking or adjusting settings. Accelerometer data shows it was set down on something, remained in place for about 11 minutes, then picked up when the battery was switched off. At about time 87 secs the AC was moved laterally on the desk.
Hum and the other files dont have records to? only to know im rigth and only have 4 log the flys
You are so good detective you say
i have to post this check my out on desk and turn on mavic lol
Thank you i learn so much today :)
Reactions: BudWalker
There is a new version of CsvView/DatCon. This new version has some new features as well as bug fixes. If you get a chance try out the MagData Player. The new versions can be obtained here CsvView and here DatCon. Both versions are a beta that will turn into a non-beta versions in a few days if there are no problems.
Hi guys,
having errors trying to use DAT files dwnld from AC
error = 'this is not a DAT file"
the GO4 DATs work with CSVwr & DatCon but not the ASS2 dwnld
any clues ?
tflys78
