DJI Air2S simulator
Hello from the Crossroads of America jhclifton.
Nice to meet you Joe. 🤝
I remember when the Spark had it's own flight simulator in the Go4 app, but DJI removed it a while back.
Good luck with the flight simulators listed above and welcome to the Forum. 😎
Welcome to Mavic Pilots! :) Enjoy the forum! Thumbswayup
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching .Thumbswayup
I had contacted DJI when the MA2 first came out about having a simulator that would work with our controllers and they said there are none that work with it and they do not plan on making it functional with any.
Welcome to the forum from the dry lakeless hills of Lake City FL. An irony... I know. If lakes grew here as much as your knowledge will, Lake City would become an ocean. ;)
Welcome again!
is there a 3rd party App that will let me use my iPad or iPhone and the Dji controller to fly some practice flights to get used to the controller, before flying the drone itself?
TIA
-joe
Yes, there is an app for iPhone, SimuDrone Virtual Drone Simulator for DJI Users.
Video Link:
App Link:
‎SimuDrone - Drone Simulator
Hello Joe,
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
As a New Drone Pilot, there are a couple of Legal Things you will need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Air 2S Drone weighs more than 250-grams (0.55 pounds) and you are required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Texas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Even while you are using the Flight Simulator or in the field, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mavic Air 2s, including the User Manual.
Happy, Safe and Legal Droning…
Reactions: GFields
TIA
-joe
Welcome to the forum, I can understand how scary this can be for your first flights, as suggested here in the forum read the manual, then read it again, I have picked up a few things on this forum which made me understand what the manual was saying about certain features, and it is amazing how much more you pick up that you missed the first time through. Provided you don't ignore some of the fly warnings, you shouldn't have any issues and the drones are extremely easy to fly, my drone 5 other people who have never flown drones were able to fly with no training apart from me telling them which stick did what.
Reactions: LoudThunder
dseyna
