Dji FPV
Dunno. It would be like learning to drive a truck in order to learn how to ride a motorbike. I'm not sure if it would add sufficient value to the learning process beyond basic safety and quad dynamics.
To be frank, when I switched to FPV, there wasnt much I could use from my previous experience with photo drones. It was like learning to walk all over again.
Good idea I will use air 2 fro few months and get experienced then would buy the FPV 🙂🙃
You will find that one does not replace the other. I have an original Mavic Air and an FPV. My son is a video gamer. Having never flown a drone before, he took to the FPV like he had done it for years. Except for the motion sickness! The MA2 will be much more stable, slower (Which is good!), and give you better video. You’ll enjoy both, but for different reasons.
Reactions: LoudThunder
I am a new drone user never used any drones but planning to buy one found some options like DJI air 2 and DJI FPV
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Since you live in India, there are specific laws and rules for you to follow, please check to ensure these are current.
I cannot advise you on which way you should lean, for the Air 2 with it's ability to take beautify photos and videos or the FPV that can fly faster than most people drive their cars. So it all depends on how you want the scenery to pass by, beautify and graceful, or so fast that telephone ples look like a picket fence…
I advise you to watch lots of YouTube Videos and then maybe you can decide. Check to see if there are local groups that fly both types of drones in your area so that you can speak to them and see what they have and what they advise…
Good Luck…
So, either way you go, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mavic Air 2 and the FPV, including the User Manuals.
After you read the Manuals, read tehm again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Happy, Safe and Legal Droning…
Black Wolf
