DJI goggles w/smart controller
The DJI Goggles can wirelessly connect directly to the Mavic 2. Why would you want to connect them to the SC?
I watched a you tube video on DJI goggles being used with Mavic Air and that’s what he had to do
If flying the Mavic Air, the goggles need to be connected to the USB port on the bottom of the remote controller. They cannot connect to the Mavic Air directly.
Could you please explain us how you did it? Thanks!!!
Simply follow the instructions. The same way as with the original controller. I am using the RE Goggles with the SC successfully. Moreover the “distance” connections problems disappear with the SC and RE Goggles so I am very happy.
mon chemin .. le masque est déconnecté ..
réglage..
paramètre de liaison ...
j'ai choisi..Mavic2
confirmer.
j'attends 60 secondes .. et rien
où est l'erreur
merci d'avance si vous pouvez m'aider
translate
my way .. the Goggle is disconnected ..
setting..
linking setting.
I chose..Mavic2
to confirm.
I'm wait 60 seconds .. and nothing
where is the mistake
thank you in advance if you can help me
It works!!!
First connected the SC to the M2P
Then linked the Goggles following the instructions, pushed the link button on the drone that went from green to red.
In a few seconds I had all running perfectly well.
THANK YOU!!
you were right..
now it works... verry well
I forgot the sync button.
thanks a lot for your help..
Kia-6098.111
