DJI MINI 2 RTH Battery issues.
My Colorado
Australia
Hi I am new to drone flying and have an issue with my drone and the batteries, while flying the RTH setting for the battery reads as zero (0). How do I fix this so it reads correctly?
Welcome to the forum from the NT. You could try resetting the firmware, I haven't had this problem myself, but find resetting or connecting the drone to assistant often resolves some of the small issues.
Regards
Regards
Thanks I will try doing that.
Welcome to the forum @My Colorado
Strange . . . to clarify, if you're flying and battery dropping normally over the flight slowly / evenly to say 35%, you hit RTH, or it goes into 'enough battery' RTH, and then it just drops out and reads 0% ?
If so, it could be some sort of firmware thing, so let us know how that goes doing an update or other such.
Could you explain your issue some other way?
I can't work out what the issue is.
Whatever it is, it's unlikely that messing with firmware would make any difference.
Perhaps take a screen capture showing what you are talking about or use a video capture app on the phone.
XRecorder works well for me on an Android phone.
Reactions: tlswift58
JesseLaw
