Mini 4 Pro batteries stored in charger?
Luckyguy9
Approved Vendor
Nassau County Long Island, NY
There was much talk about the Mini 2 batteries being stored in the charger.
But I haven't seen anything about that regarding the new batteries for the Mini 4 Pro?
There are a variety of cases, some with the layout for the batteries separate from the charger hub and others with the batteries in the charger hub. See photos below. Which is best and why?
And THANK YOU to the 4000 who read and 98 who graciously replied to my question, "When do you use RTH?"
Reactions: AviatriXXX
The same likely applies if you're referring to a charging hub. If the hub is not connected to a power source, then you can store your batteries in the hub. However, I'm not sure there are any advantages to storing batteries in a hub outside of something like you're showing above.
The best case for you is the case that can store all of your accessories.
I store my M4P batteries IN the hub and, at least for my case you can't connect the hub to the charging cable in the case.
Reactions: atomicpuppies
bullet_magnet
