Video as well, no watercolor affect anymore. The opening shot as well as the waterfall are Mavic Pro.
What resolution and Frame rate did you use on the Mavic Shots?
HI,
Just watched this video and you are correct, "NO WATER COLOUR PAINTING" because it looks as though the video was shot 2.7k or 4k. It's really only the 1080 50p or 1080 60p resolutions the Mavic Struggles. Take a closer look at the video and you will notice there were no high speed pans or movements. This hides the low 24 or 30 frames per second stuttered movement (motion) that 2.7k and 4k produces on the Mavic or any other camera for that matter. So the trade off is jittery (High Speed) motion in 4k or 2.7k (tracking subjects at speed or panning) or Aliasing Moire and the possibility of "Water Colour Painting" (caused by Low Light and incorrect focus & Shutter Speed) image in 1080 50p 60p. It still doesn't help us that the Mavic is a little unpredictable when filming in 1080 50p 60p but this is the resolution and frame rate you will see issues not 4k and 2.7k.
I don't believe style modes have an affect on raw images as raw images are just that, raw. So the only thing you will take away from your image is the entire image data. Art is still a viable option using either Litchi or the original dji go app (which as another user said when selected shows none in the profile on the dji go 4 app) perhaps an issue with job compression? I believe if you shoot in jpg your color style and profile will be transferred onto the image, so if your sharpness is too low will muddy it quite a bit. I never shoot in jpg. Also are you taking the photos off of your phone from the stream of the mavic or off of the SD card? I shot this video in art mode - 1-3-3 then color graded in fcpx. Exposure was set to auto and I believe my white balance was set to sunny.
Sent from my SAMSUNG-SM-G935A using MavicPilots mobile app
Filming in 1080, 2.7 or 4K is not the reason.... I only have filmed in 2.7 k and still get it...
Granted shutter speed could cause an issue but it most certainly isn't resolution.
I short at 4k 30 but have been using 4k 24 lately and everything looks good
To add to this, lower fps will give more data per frame captured (Mbps). Ie. 60 fps will use half the data per frame than 30fps.HI,
Yes, you are correct. I suppose it depends on what each of us is trying to achieve. If you are filming fast moving subjects or lots of pans then smoother (Fluid Like) motion will be a priority. if we are filming scenery and slow movement then higher resolution with lower frame rates will be best.To add to this, lower fps will give more data per frame captured (Mbps). Ie. 60 fps will use half the data per frame than 30fps.
Sent from my KING7 using MavicPilots mobile app
HI,1080p 60fps is used for FPV, it does not encode well as that mode has been optimized for low latency not high quality. 4K has low bitrate (only 60Mbps, should be 100 Mbps as with P4 Pro). Seems 2.7K/30 is the best choice on Mavic. YMMV.
4k 30fpsHi, Great Video. What resolution and frame rate did you shoot the video ?
Just watched it again and I think I can answer my own question.
Let me guess, shot in 4K or 2.7K at 24, 25, or 30 FPS.
You can see the motion blur on the fist shots with the medium speed pan.
Let us know.
HI,
Just curious, where did your information come from regarding 1080p used for FPV ? I have read this in many forums but not sure how correct it is. I had a look at the data rate for 1080p and it is just as good as the Phantom 3? I will have another look at this though.
Gimbal roll is your horizon adjustment, not rate of movement. This comment was about the horizon level only.Gimbal roll has nothing to do with this and my gimbal roll is lowered to a slower speed my friend ! : )
Should not, but this is not a professional camera, obviously. I would love it not to be an issue, but it occurs under certain frame rate settings, as well as some exposure or profile settings. If you have to shoot under certain protocol or conditions, a minimal effect can be acceptable for some. Watercoloring does not exist on all footage.“watercoloring is minimized” should not even be a issue to minimize !
I think it looks pretty good also.How does this video look? Only my 3rd flight. It think the settings were -2, -1, -1 UHD @ 24 FPS, auto WB, no post. I think it looks decent, but who knows...
Sent from my SM-N920P using MavicPilots mobile app
