I am in day 3 with my mavic and after 6 flights I am convinced I have the same problem. It moves up and down up to a foot and drifts all on its own side to side a bit up to 1-2 ft. It isn't holding firm and we are talking about no wind conditions. I have been calibrating compass every other flight just to see if it helps and also scared to find out what happens if it isn't calibrated correctly
Also sometimes when return to home the bird wont decend and just hovers up high few hundred ft above landing spot and I have to manually decend and then it starts doing the landing. This has happened twice for sure and both times it was dark outside.
The last thing is the return to home. It usually is like 3-4 ft from take off spot in a variety of conditions and take off spots. This may be normal or expected behavior ? I thought this thing mg was suppose to be more precise and even took a photo of the ground after launch to help with accurate RTH.
