Firmware Update alert every time I change the battery in my Air 2
T'Jingles
Oklahoma
Air 2 firmware 01.01.0700: SC firmware 01.01.0064: GoFly App version 1.5.4
Since updating the A2 firmware to 01.01.0700, every time I load a new battery, the Firmware Update "Update" alert appears when I connect to the aircraft.
Checking if update is required reports firmware is up-to-date.
If I tap update, it always starts at 70% and runs until installed successfully.
If I don't tap update, A2 and SC seem to operate normally.
Looking for possible causes and/or solutions.
@T'Jingles it could be that its a battery only update ,when you do a firmware update ,then if the battery is part of that update the one in the drone will be updated ,then when you put in another one it will ask you to do an update ,and so on till they are all updated
@T'Jingles glad it sorted out your issue
thats what makes this forum so great
being able to offer solutions to issues
happy flying OMM
Reactions: RMS001 and zeusfl
As @old man mavic mention is battery only update. I like to do it over the DJI Assistant for Mavic for Windows or macOS instead to make sure everything is updated even the controller.
Reactions: old man mavic
Andrefu
