I have an easy fix for the Mavic Pro Controller Buzzer, "FlightClub Easy Fix".
If you hate the annoying Controller Beeping when you enable RTH on the Mavic Pro Controller I can give you a solution to make it an adjustable volume or completely disable it. Late last night, I performed the modification to my controller. Today I am happy to report, that after performing three full battery flight tests; the annoying Controller beeper has been defeated, and that the Mavic and Controller, operate perfectly as designed....... minus the annoying, ill-wanted, nerve-racking, neighbor-attention grabbing beeping sound. And, if you follow my directions precisely, you will have complete control to easily set the volume to any desired level, including the ability to completely disable it. I am extremely pleased with the results, and the flying experience is much more enjoyable!
I have created an easy to follow procedure with diagrams and complete tool & material list, which requires no special technical abilities and that can be performed with tools & materials that are readily available.
To ensure the modification is a success, it is imperative that measurements for the centerhole are carefully executed and most importantly, THAT THE WHOLE IS DRILLED BY HAND, per the procedure. And to be perfectly clear, the hole is to be drilled by placing the drill bit in one's hand, and then the hole is created by applying pressure while twisting the drill bit with your fingers into the back of the controller until the metal piezo element is visible. Once you can see the metal disk, use less pressure on the drill bit to clear the remaining Contoller plastic until it is a full 2.4mm in diameter.
Enjoy the peace and quiet
