From Canada's National Capital (Not Toronto!)
Welcome to the forum!
It's good that you made clear that Toronto is not the National Capital in your title as many members from outside of Canada may think it is our capital since it is the most populous city.
Enjoy the forum.
Chris
Enjoy the forum.
Chris
Welcome to both of our Canadian friends. All it takes is one trip to Ottawa to know it's the capital; never going to forget the unique look and feel of the city.... 🇨🇦
Should keep my Mavic 3 Classic happier for awhile!
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mavic 3 Classic, including the User Manual.
Fly On and Fly Safe…
Andrefu
