Speaking of gimble movements is it ok to move gimble to fit it into the gimbol retaining storage bracket. It feels so flimsy and sometimes it turns or flips around as you try to navigate it into the plastic retainer clip. I worry about messing it up or something.
Oh really i was under impression phantoms had yaw control. Wow shows what I know. Like i said i never owned a complete one. I only bought the mavic cuz i learned bout it researching the p's
My opinion, based on a fair amount of experience, is that you do not need (or want) seperate yaw control of the gimbal.
First, you yaw the camera by yawing the aircraft. That works fine. Visually there is no way for someone watching the video to tell the difference.
Second, it is much much much more difficult to fly when the camera is not facing forward. You need to be constantly aware of how many degrees you've rotated the gimbal so that you can work the sticks correctly to fly in the direction you want. It takes a lot of concentration and it's still hard.
I fly an m600 with full independent gimbal yaw control. When I'm flying it alone, I set it to the exact same setup as any Phantom or Mavic. In other words I lock the gimbal to a forward view and put it in Follow mode.
If I have a dedicated camera operator, then and only then, do we take the gimbal out of Follow to allow him to operate it while I fly. But even then, I fly using a second fpv camera (a GoPro) that is locked to a forward view (and doesn't even have a gimbal).
And one other point. Drones with independent yaw for the gimbal/camera also have retracts (retractable landing gear) to get out of the way of the camera.
Uh, of course you can tell the difference when your piloting.I can tell the difference when I'm piloting the craft simply by the direction of terrain movement while flying, assuming I'm flying straight and not laterally.
That is already available. That's how you know how many degrees off your camera is. Like I said before, it's very difficult to keep constant track of your offset. It's really hard to keep your bearings. And again, what's the point? Your footage won't benefit in any way.Your second point I agree with though. That is why I would suggest an indicator on the HUD displaying the gimbal offset.
It is just as effective if the yaw of the entire craft is controlled by the goggles. That's how a lot of these setups for consumer drones already work. In fact, the Litchi app will allow you to do this with your Mavic right now.I think I may have not been clear in how this should/could be implemented. As I imagine it the gimbal would controlled by the fpv goggles, so all that is required to move the gimbal is looking around.
My point is that visually there is no way a viewer watching your video can tell the difference. Whether it is the entire craft yawing, or just the gimbal/camera, the end product on video is the same.
Hey now. No reason to get upset. What possible offense could you have taken to anything I said?I'm not concerned with making videos, my intention is to enjoy it live. Also not producing footage, that OK with you? Can I desire to use my property how I see fit? And quite obviously the current implementation of the gimbal offset HUD is for pitch, not yaw.
Perhaps you have a hard time flying and keeping track, but others may not. And finally, the point is I would enjoy it.
It would be nice if Go 4 or litchi could be updated to allow yaw control.
Was that road a sheet of ice or what! haha nice flying.Check out this video I made... you still think you need yaw control on your gimbal!? LOL
--Atomicbear
With Mavic landed moving the yaw stick rotates (only a few degrees) the gimbal. With Mavic flying, obviously moving the yaw stick rotates Mavic.
and maybe some other professional unitsI think only the inspires have them and they require two pilots and remotes because of it.
Have you already tried switching the gimbal mode in the Go app? I know it doesn't allow manual yaw control, but maybe it gives you closer to what you're looking for. Also, I believe Litchi has a few different options for FPV and gimbal control. I haven't tried any of them, though.
