GIMBAL
Is the gimbal seated correctly. It should be underneath the front and rear tabs. Just sounds like it is not in the correct position and that is causing the knocking noise.
It looks right to me but...
Figured it out partially. The knocking noise is the gimbal swinging to fast
It isn't supposed to be doing that, try doing a gimbal calibration... if that doesn't help then return it
Reactions: kingbrad22
seems to me that the gimbal is performing the startup procedure like it did on earlier firmwares.
Believe that the .500 included optimized gimbal calibration that slowed down this procedure.
What firmware are you running?
Tried it. It started working properly. Everything was good. Reset the drone and it started the knocking again
The newest one, .600 i think it is
Bsplum
