Greetings from Dogtown St. Louis, Missouri
I have the Mavic Mini and am having a hard time figuring out how to change exposure in PRO Mode.
I've included the User Manual at the end, perhaps that will help, if not, YouTube is the place you might want to see the process in action…
If you are a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs less than 250-grams (0.55 pounds) and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live Missouri, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini, including the User Manual.
Fly On and Fly Safe…
Hi,
I have the Mavic Mini and am having a hard time figuring out how to change exposure in PRO Mode. I can change ISO and shutter speed, but not the exposure level. But it allows you to change exposure in AUTO Mode. Not sure what to do here. Any help would be appreciated.
Welcome to the forum! There is no aperture on a Mini so the only way to control exposure is shutter speed and ISO. The thing you are changing in AUTO mode is Exposure compensation. The way meters work is averaging 18% gray so if you have an overly bright or dark scene, you may need to use compensation to adjust exposure correctly.
BTW, I was down filming in your area yesterday, I grew up in the city and the architecture and small neighborhoods are so full of history. It's a shame what it's become, hopefully the people will take it back and give it the sense of community that it has always deserved.
Welcome to the forum. You came to the right place for support. Check in on the Mini thread. We look forward to your participation and your view of the world.
I lived in St. Louis (Florissant) for a few years.
Welcome to our forum, Martini, from Hauptmann, in Hurst, Texas!
You'll love the flexibility of vantage points an aerial camera platform affords--you'll get shots and videos you could only dream of before! I fly a Mavic 2 Pro now, but will soon add a Mini 3 Pro to my “fleet”.
We have over 150,000 members—many from St Louis--who enjoy helping each other get the most out of our hobby. Most of the questions you'll have will’ve already been addressed, and are easy to search. If you have NEW questions, just ask!
I've attached a couple of links below, which will make learning piloting and photo/video skills easy. The author specifically refers to the Mini 3 Pro, but his “moves” apply to any drone (DJI, anyway).
Glad to have you with us!
Rich R (aka Hauptmann)
https://www.youtube.com/watch?v=c1j9VqmDYEI&t=497s
https://www.youtube.com/watch?v=vK6s2hJLRRE
bullet_magnet
