Greetings from Rio, Florida! Pronounced Rye-o.
Have Mavic 2 with Part 107 in pocket and cool areas to get to. Looking forward to some great experiences and footage.
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2 and I know the excitement you are going through…
We have a Member's Map in the Upper Right of the Title Bar, Tap "Members", Tap "Member's Map" Members map
Since you are in Florida, there are a couple of Legal Things you may need to do…
With you already having the Part 107, I do not know if you will need to get your TRUST Certificate. But it you do, you can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone. I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
Link to the Pilot Institute Web Site (FREE…) FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Link to the FAADroneZone (Optional for Drones under 250-Grams…) FAADroneZone
Below is the link to all of the downloads offered by DJI for the Mavic 2 Pro Zoom. You will also find the 69-page User's Manual, in case your Drone did not come with one.
Happy and Safe Droning…
Greetings from Birmingham Alabama, welcome to the forum!
WELCOME to the forum :)
Welcome to the forum, great bunch of people, friendly and helpful.
If you have any queries just ask, someone will eventually have the answer (99.9% of the time) or im not an alien.
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to the forum! :)
dozerdan
