Greetings from the west slope of Colorado
Welcome to the forum! :)
A few useful things to get you started:
  • The current Air 3 manual can be downloaded here (it doesn't come in the box).
  • You can find other commonly used downloads on the Air 3 downloads page.
  • This video covers all the basics of the Air 3.
  • Your drone batteries will last longer if you use and maintain them like this.
  • The drone records flight data each time you fly. You can decrypt and view those flight logs with these tools.
Hello from the Crossroads of America hank970.
Nice to meet you Hank. 🤝
Welcome to the Forum. :cool:
My name is Hank, and I'm new to the hobby.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Colorado, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mavic Air 3, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum from the beautiful woods of Maine!
There’s many knowledgeable members who are willing to help you with any questions you might have. Search the forum using keywords and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response! Fly safe and stay safe!
Welcome to the forum We look forward to your participation and your view of the world.
peehead
