Hello from California
Hello from the Crossroads of America Later2u.
Welcome to the Forum. :cool:
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
I'm a recent owner of a Mini 2.
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
To Fly a Drone in the USA, there are a couple of Legal Things you may need to do…
You will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
Link to the Pilot Institute Web Site (FREE…)
Link to the FAADroneZone (Optional for Drones under 250-Grams…)
Since you live in California, there are specific laws and rules for you to follow, please check to ensure these are current.
Now, for some Good Old Fashion Advice…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
The Gimbal is the most delicate item on the Drone and banging or bumping can damage it. I also fastened a short "Remove Before Flight" ribbon to the Gimbal Cover so it's more noticeable and I do not forget to remove it…
Turn on the Drone and watch it come to "life." Watching the Gimbal go through its self-check is almost like watching a kitten or puppy opening its eyes for the first time…
Place the Drone down (preferably on a Landing Pad) while it finishes its self-test (collecting satellites, etc…).
Check your battery status (Phone, Drone, and Controller), check the Signal Strength (5-Bars), number of satellites (at least 10) and by now the Controller should have reported it updated the Home Point.
If you go out in a rush and race thru your start up and take off before the drone has finished it prep, it may update its Home Point over that pond or that old tree you are flying over and in your excitement, you'll fly the drone long past it Low Battery Point and when it engages Return to Home and lands in the pond or in a tree; it will be all on you…
Now go have fun, learn to fly the Drone by sight before you try to fly it out a distance depending on the video feed, first-person view (FPV).
Below is the link to all of the downloads offered by DJI for the Mini 2. You will also find the 75-page User's Manual.
Happy and Safe Droning…
Hello everyone,
I'm a recent owner of a Mini 2. I look forward to participating with the forum.
I wouldn't be truthful if I didn't mention that I found Mavicpilots because I made a mistake and am searching for advise. :)
My next post will be in the Mini 2 help forum. :(
Thanks for having me.
Welcome to the forum!
The mini 2 is an amazing drone and you have came to the right place for knowledge and advice!
Thanks for the info LoudThunder.
California sucking the fun out of everything. LOL
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum! :)
Hello everyone,
Welcome to Mavic Pilots from Dayton Ohio USA! Fly safe and have fun!
dochavez1986
