Hello from Cleveland OH w/ a Mini SE 2
LBM
Cleveland Ohio
Site
lnk.bio
Hello, I am new to these Mavic forums but I am not new to drones after piloting a Spark several years ago, I am getting back into the hobby with a Mavic Mini SE 2 that I should be receiving in the next couple days.
I’m pretty certain I will need an adapter for my iPad mini 5, if someone can point me to an adapter that will fit I will much appreciate it, I realize that there will be a lightning cable that comes with the drone but Im wondering if that would be long enough for my iPad.
Any help would be much appreciated, thank y’all!
I’ll post updates on the lil mini 2 after I fly it.
Lou
Welcome to the forum. We look forward to your participation and your view of the world.
Hello from the Crossroads of America LBM.
Nice to meet you. Lou. 🤝
I'm a fellow Spark pilot myself, well, until it RTH under the tree canopy. Do'h !
Still flies fine but the gimbal is compromised.
Here is a holder that's simple to use and still allow the DJI stock cable to work.
There's others available as well.
Have fun shopping and welcome to the Forum. :cool:
TY friend, hopefully you're correct about the cable. The mini ipad fit that old RC perfectly..
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Ohio, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini SE, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum! :)
Welcome to our forum, from Hauptmann, in Hurst, Texas!
You'll love the flexibility of vantage points an aerial camera platform affords--you'll get shots and videos you could only dream of before! I fly a Mavic 2 Pro now, but will soon be upgrading to the Mini 3 Pro.
We have over 150,000 members—many, many from Ohio--who enjoy helping each other get the most out of our hobby. Most of the questions you'll have have already been addressed, and are easy to search. If you have NEW questions, just ask!
I attached a couple of links below, which will make learning piloting and photo/video skills easy.
BTW, One of my sons and I were in Cleveland last June. Had a blast. Toured the R&R Hall of Fame, spent the next day at Coastermania in Cedar Point. Want to come back for the NFL Hall of Fame and tour Wright Pat USAFB. Maybe next year.
Glad to have you with us!
If you read the OPs post he clearly states that he is NOT new to flying drones, he is just new to the forum. He states that he has been flying for a good while.
Reactions: LoudThunder
Rambezito
