Hello from Fairplay Colorado
I will be flying a Mavic Mini 4 Pro.
You might want to also join a sister site, Ma
You don't say how long you've been flying, so as a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Colorado, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
vicPilots
Welcome to the forum! :)
Welcome, I was in Fairplay just on Friday. I fly the Brannan yard there everyone month. And you also look into joining the Mountain West UAS group. They meet at the Buena Vista Airport (& other places) the first Saturday of each month.
Also, you'll usually get the warning on your controller that you're flying at high altitude when you fly up there if you didn't already. Just ignore it. You'll be fine.
Here's a fun little pic I did put together from a few shots while I was flying in Fairplay on Friday.
vicPilots
Thanks for all of this information. I have my certs and have registered.
Reactions: LoudThunder
Cool, I know the area well. I get that high altitude warning in Denver also.
seacorope
