Hello from Liverpool
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Hi, I have just got my first drone a mavic mini 1, I am off to the laungadoc cather region in Spain on my holidays…..I can’t wait to try it out getting pictures of all the old mountain top towns.
Welcome from across the pond in Canada 🇨🇦 Say, hello to all my Scouser friends…safe and fun flying 👍
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum! :)
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
And since you are going to Spain, you need to know their laws and rules…
As a Newbie, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini, including the User Manual.
Happy, Safe and Legal Droning…
Reactions: Chetk7677
Hi and Welcome to the forum, hope you enjoy , cheers Len
Pleopard
