Hello from Madison, Wisconsin!
OMC
Madison, WI USA
Happy Fathers Day! I am new to the sport. I have a photography background and am hope my new Mini 2 will enable me to get a new perspective. If anyone is around southern Wisconsin, I would like to hear where some good places are to fly. Madison is pretty restrictive to flying with the airport so close. So any advice would be appreciated! Thanks and have a great Day!
Welcome to Mavic Pilots .
Don't be shy and ask anything if you can't find it by searching
and stay safe.. Thumbswayup
Hello from the Crossroads of America OMC.
Welcome to the Forum. 😎
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2 and I know the excitement you are going through…
We have a Member's Map in the Upper Right of the Title Bar, Tap "Members", Tap "Member's Map" Members map
Since you are Flying in Wisconsin. there are a couple of Legal Things you may need to do…
You will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone. I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
Link to the Pilot Institute Web Site (FREE…) FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Link to the FAADroneZone (Optional for Drones under 250-Grams…) FAADroneZone
Below is the link to all of the downloads offered by DJI for the Mini 2. You will also find the 75-page User's Manual, in case your Drone did not come with one.
DJI Mini 2 - Download Center - DJI
Happy and Safe Droning…
Welcome to Mavic Pilots! :) Enjoy the forum!
Welcome to the forum! :)
Welcome to the forum from the mountains of Colorado! Happy and safe flying!
Welcome to the forum and I've enjoyed flying at Indian Lake, which is a great hiking park, and is a little Northwest of Madison.
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum from just south of Houston.
Pleopard
