Hello from Mickleton, UK
Hello from the Crossroads of America Muttlee66.
Welcome to the Forum. :cool:
Hi everyone is there anyone in my area interested in meeting up sometime?
Since you live in the Uk, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
What are you flying?
Fly On and Fly Safe…
Welcome to the forum! :)
Welcome to the forum from the bowels of California!
sevimli
