I picked up a Mavic Air 2s this past summer as my first step into the drone world. I'm primarily a photographer, and a 20mp camera on a "tripod" I can raise up to 400ft in the air opens up amazing possibilities. It has been a lot of fun so far.
Thanks for all the info! I should have introduced myself soonerWelcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar. Click on "Members" and then Click on "Member's Map…" Check it out and you might find some new flying friends.
Member Map
mavicpilots.com
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.trust.pilotinstitute.com
FAADroneZone
faadronezone.faa.gov
If you are considering acquiring your Part 107 License, here is a link to get you going…
Online Ground School: Aviation Classes - Pilot Institute
Pilot Institute offers courses on drones and airplanes from world-class experts. Pass the Part 107 or Private Pilot exam and take to the skies.pilotinstitute.com
Since you live in North Carolina, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Drone Laws and Best Places to Fly in Every US State - Pilot Institute
pilotinstitute.com
Below is the link to all of the downloads offered by DJI for the Mavic Air 2s, including the User Manual.
Happy Droning…
Where can I find the guidelines?Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching .
Well I'm glad to meet ya… I'll give you just a bit of a shove towards the Part 107 License. I took the Exam just a couple of weeks ago and I aced the Exam. Do not be shy, anyone who is primarily a photographer with a 20mp camera on a tripod that can raise up to 400-feet needs that license…I've considered pursuing Part 107 licensing, but haven't committed to that yet.
Welcome, you must be near Apex NC, I have flown at Holly Springs when visiting Apex.I picked up a Mavic Air 2s this past summer as my first step into the drone world. I'm primarily a photographer, and a 20mp camera on a "tripod" I can raise up to 400ft in the air opens up amazing possibilities. It has been a lot of fun so far.
