Hello from NW Ohio
Conejo148
NW Ohio
Hi all,
Just dove into the drone-sphere last week with a Mini 4. Finally had a few days where the wind was sub-20mph to get out an play. It's hard to believe the amount of technology crammed into such a tiny device but man this thing is fun! Anyway, looking forward to learning from y'all in preparation for some upcoming trips.
Hello from the Crossroads of America Conejo148.
If you haven't done it yet, you need to take the TRUST test and keep a copy with you when you fly.
It's a free no fail test that's easy to take that covers the basics of flying a drone.
Good luck, have fun, and welcome to the Forum. :cool:
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Ohio, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum. We look forward to your participation and your view of the world.
BinaryBandit
