Hello from Salzburg, Austria
Hello from the Crossroads of America tischa8590
Nice to meet you Dennis. 🤝
Welcome to the Forum. 😎
just got my A2S and now pretty happy I found this site :)
If you'll ever get to Salzburg, Weißwurst und Brezel are on my bill.
Stay stafe and healthy.
Dennis
Dennis
Welcome to the forum from the mountains of Colorado! Happy and safe flying!
Welcome to the forum! :)
Dennis
Dennis,
I will be there in July for the F-1 race in Speilberg. Will be coming with my new Mini 3 (if it gets released soon.). I am looking forward to returning to Austria once again.
Greetings from Birmingham Alabama, welcome to the forum!​
Welcome to Mavic Pilots .
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome from the Hampton Roads area of Virginia, USA. I am a Mini 2 Flyer and I know the excitement of flight. So, if I may offer some advice.
I would also advise you to use YouTube and watch a lot of the Videos on flying and setting up the Mini 2. When it is too dark, too cold, or too wet, you can "fly it vicariously" through YouTube. Also watch some of the Blooper Drone Videos and learn how not to fly your "New Baby."
Below is the link to all of the downloads offered by DJI for the Air 2S. You will also find the 57-page Air 2S's User Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
Happy Droning
jlhdez
