LoudThunder
Part 107 Licensed
Recreational flyer here, with Air2S. Started out with a Sharper Image drone gifted to me. I learned quickly that 7 minutes battery life was a buzzkill. Was into GoPro cameras and went full tilt to the Karna system, but after experiencIng chronic controller connection issues I sold out and bought a second hand DJIAir2S. Getting acquainted with the unit and its capabilities and am having a little fun with it.
Great reading here.
(and yes, I’m FAA compliant)
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2 and I know the excitement you are going through…
Good to know that you are FAA Compliant!!!
With your "New Baby, do not let the excitement of the moment get the best of you. When you are going out to fly, do it slowly and deliberately. Get used to a set procedure and even practice it.
Below is the link to all of the downloads offered by DJI for the Air 2S. You will also find the 57-page Air 2S's User Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
DJI Air 2S - Download Center - DJI
Happy and Safe Droning…
