Hello from Virginia
Welcome to the forum! :)
Welcome to Mavic Pilots!:) Enjoy the forum!Thumbswayup
Welcome to the forum, from Hauptmann, in North Texas!
You'll love the flexibility of vantage points an aerial camera platform affords--you'll get shots and videos you could only dream of before! I fly a Mavic 2 Pro now, but will soon be upgrading to the Mini 3 Pro.
We have over 150,000 members who enjoy helping each other get the most out of our hobby. Most of the questions you'll have have already been addressed, and are easy to search. If you have NEW questions, just ask!
Glad to have you with us!
Rich R (aka Hauptmann)
I'm in SE Virginia (Suffolk) and run an Avata and Air 2s.
You might want to also join our Sister Site, FPVDronePilots, linked below and at the bottom of this web page…
Also check out Facebook, Virginia Drone Pilot Group…
You did not say how long you have been flying so there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drones weighs more than 250-grams (0.55 pounds) and while you are flying under The Exception for Recreational Flyers, you are required to register your Drones.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Virginia, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Fly On and Fly Safe…
Whitehammer661
