Update and a few facts from my side:
had the last disconnect on friday (18.11.). Here app disconnected from controller, I used RTH button on controller and all was fine.
- I'm using a Samsung Galaxy S7, side USB port to controller
- Mavic is on current firmware
- on the same day I noticed a DJI Go app update (android now on 3.1.0(7))
- since this I didnt have an disconnect (had 4 flights since then, on different locations)
what I'm trying on the phone:
- close all apps, clen up memory (with smart manager)
- GO INTO Airplane mode (this is my biggest suspect, could fit to a few guys here reporting they had it in very remote areas as well - remote area: low cell coverage - phone runs in high power mode?)
- try to have a fully charged phone (my suspicion here: if the controller has to charge the phone with too much amps the USB port is disabled from the controller side. this is why it only works again if you reboot the controller) That being said, this morning my phone was at 65% and I flew 12mins with great morning light... no disconnect.
I will continue to perform this steps prior to each flight and report if a scary disconnect happens again.
If no disconnect the next week, I will try flying and testing without airplane mode on the phone.
Would be cool if someone here that can "reproduce" disconnects would also try to see if airplane mode has an impact?
Hope this is fixed already with new app version? Thanks for participating in this riddle.
OBSTACLE AVOIDANCE?!?!
The only other little issue I found so far: obstacle avoidance freaks out if flying directly into the sun.
Had a high pulse moment shortly when that happend and I was quite far out, the drone wouldnt move fwd anymore
I switched to Sportmode (which disables obstacle avoidance) and it was fine again!
greets, RCSchim
