dont know if theyre any drone owner down here with all the restricted airspace we have down here,
mavicpilots.com
I looked up Miramar, Florida, and although you have a bunch of Class D Airspace; all you have to do is ask for Authorizations from the FAADoneZone. You need to create an account there since your Mavic Pro is required to be registered… I live in a similar air space region, an Air Force Base, an International Airport, and an Army Air Field, and I have just over 20-authorizatrions so I can fly for fun…
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs more than 250-grams (0.55 pounds) and while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
When I first started flying I registered my
Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com
faadronezone.faa.gov
If you are considering acquiring your Part 107 License, here is a link to get you going…
Pilot Institute offers courses on drones and airplanes from world-class experts. Pass the Part 107 or Private Pilot exam and take to the skies.
pilotinstitute.com
Since you live in Florida, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
pilotinstitute.com
Below is the link to all of the downloads offered by DJI for the Mavic Pro, including the User Manual.
At DJI Download Center, Learn aboutMavic Pro
www.dji.com
Fly On and Fly Safe…
