Hi All
allenjr
Ireland
Hi all....
Just joined the group.
I'm live in Ireland but spend some time in France also.
This will be my first time using a drone and a little nervous in doing the first flight
So I'm totally just finding my way around and looking forward to learning as much as possible from this group..
regards
John
Since you live in Ireland, (the UK) and spend time in France, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Let us know what you are flying and we might be able to hook you up with some great Links…
Fly On and Fly Safe…
Hi all....
regards
John
Hello from the Crossroads of America allenjr
Nice to meet you John. 🤝
Welcome to the Forum. :cool:
Thanks LoudThunder for all the great advice..
A very slow start will be my main focus... and out in the middle of a large field with NO Trees........
I'm flying the Mavic 3
Thanks again for the advice..
Remember, it's those fast stick movements that will get you every time. Is it the Right stick that make the drone go Up or is it Forward? Practice those stick movements out in the open and not near an obstetricals (trees or buildings…) and until you know that, do not try to fly it in the house… You'll take out the ceiling light or overhead fan… and scare the bejesus out of any pets…
Below is the link to all of the downloads offered by DJI for the Mavic 3, including the User Manual.
Have Fun, Fly Safe…
@allenjr welcome to the forum
depending on whether you live in Northern Ireland or over the border ,will dictate ,which rules you will need to fly under, if you are part of the UK then CAA registration will apply, if part of the EU then you will be good for France as well
Hi all....
regards
John
Hi From South Wales, hope you enjoy the forum, fly safe , cheers Len
Thanks...
Yeah.... it is a really nice country... but bring rain gear with you... that's why it's soooooo green.. just joking....
I understand sir. Washington state was the very same way. Very green but you were always trying to figure out ways not to get wet😁
Whitehammer661
