Hi From A Lonely Droner!
Hello from the Crossroads of America Telthecelt.
Thanks for sharing the great views.
Welcome to the Forum. :cool:
There's less chance for drone flying in Scotland than I had foreseen (silly me!)
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
@LoudThunder Time to turn this into the welcome e-book! : )
WELCOME to the forum :)
@Telthecelt hi and welcome to the forum
your not alone ,my wife has absolutely no interest whatsoever ,in my drone hobby
Welcome to the forum! :)
Much obliged for all that sage advice. Thank you. I'm still at the intense concentration stage launching and flying the thing. I've watched many great drone pilot's instructional videos and am grateful to them also. I've passed the CAA test and registered my aircraft as required by UK law. Putting my phone number on the bottom is a good idea I will adopt!
Reactions: LoudThunder
I have seen so many wonderful video coming out of the countryside. Be sure to watch videos on making videos and taking photos. It seems that the most accidents occur when one is concentrating on getting that perfect photo or making a dramatic video.
Hope to see some wonderful from you, Good Luck!
whathesaid
